G Series Specs
5 hours ago, nbs. said:
I now have the g series remote controlling volume without opening up subtitles
They probably made a box especially for you.
  • Replies 81
  • Views 8.1k
  • Stugots
    Stugots
    Just to clear this up, BuzzTV G-Series is a certified Google TV device, so the platform and firmware update process is different from our regular Android boxes. There are multiple parties involve
  • Stugots
    Stugots
    What you are describing is an oversimplification of how a certified Google TV device works. This is not a typical AOSP box where one party can freely control and modify the firmware and update path.
it's because he isn't an idiot like you
Actually the box YOU received was customized just for you.  As soon as you plugged it in, it detected your hardware configuration, sent the configuration back to the mother ship, and it then proceeded to adapting the last remote firmware you got, to ensuring you would be frustrated.
Everything you want. But right now buying a G-series is buying a brick. You can say whatever you want, but this is a brick.
Well mine controls the volume correctly and does everything else it is supposed to So I take it that you have no idea how to run the unit
12 hours ago, El Kaiser said:
I'm sure Google will release a new firmware for the remote control. And I'm also sure it won't be in the near future.  For now I have the Buzztv as a paper weight. Stop being such a Fan Boy.
you sounds like a kid pal. I have been fan of buzz devices and their features and support from years. I almost own every model of buzztv released by buzz team in last 8 years. I appreciate their generous donations and their products never disappointment me ever. therefore, I have many people have many buzz devices in my country.
No one received a custom unit. We had to set them up just like you.
I had the same issue as you with it opening up subtitles. I then spent time working and figuring it out with the dev. Issue is resolved with a few changes in settings.
Brick? The only brick here is your thick scull.
It is on the Google Play store.
But be careful, there are 2 versions, but one version is intended to be for mobile devices.  For the Gbox, you want the one on the left in the pic below.
  • 3 weeks later...
I bought the box and I am in the UK I like the box it's snappy etc.  Buzz TV 6 app is an early release on playstore and has a long way to go by the looks of it.
The remote recently got an update and I haven't had many problems once I configured the buttons in the menu and I use a denon x4700h avr.
I can confirm that most codecs / passthrough works fine in Kodi but only Dolby digital or Dolby mat is available in the menu with no full passthrough option for the moment.
AISR does seem to work fine and requires no configuration.. Hopefully full passthrough will come and the buzz TV 6 app update gets released soon as I wouldn't use it in its current state.
I am having issues with usb external storage though just keeps rejecting it in either the C port with an adapter or in the USB A port. I may need to format it in a pc first.
But it's early days and hopefully as a premium device the passthrough will be fixed but I believe it's the same issue across all s905x5 m boxes at the minute.
Update usb needed formatted to exFat and now works perfectly as external storage using usb 3.0 128gb flash drive and a usb c to usb A adapter. Was able to record using another IPTV app and playback was fine.
We have a few people who work for us in the UK
and we have found out that Google has different settings menus for Google TV Devices based on region
As boxes being used in North America, for sure have the Passthrough settings
We currently have no control over this
And can you please give feedback on Buzz 6 app? So we can look into it
Why did you need an adapter ? The flash drive didn’t work in the 2.0 usb slot ?
Buzz TV 6 app
Will not hold grid layout
No settings to merge playlists
No just for speed usb 3.0 Is faster
Also grid layout looks terrible looks like STB emu from years ago.When you get to grid layout and want to change category it reverts back simple layout. Pvr function is not shown or I can't find it. I fine it awkward to switch from live TV to vod etc as well. App is quite quick to be fair. But really needs polished the UI.
Would like to be a tester for the buzz TV 6 app if possible for g series
8 minutes ago, D L said:
Buzz TV 6 app
And it was for recording IPTV so thought speed to read / write would help. Worked well using another player I use as don't think it's available yet on the early release buzz TV 6 app for g series on playstore
what do you see when you press menu button in live tv?
Where is menu button
We had to disable PVR on the Playstore version when we submitted it, as we need to look into Googles guidelines for Permission settings on apps that require the permission for Files and Media etc. They're very strict when it comes to this.
1 hour ago, Ryu said:
When you open buzz app press left arrow
A ok not menu button on remote control...Yeah I found this main menu option and if your hit blue button while hovering over EPG it brings up this.  This is the way I would like the EPG to hold but does not if you hit left you go back to regular epg
