G Series Specs
44 minutes ago, Joe Reid said:
Hi, I took delivery of my G series box today. Just need a bit of advice about using the"buzztv 6 app" , including the remote. Is there a way to access the epg guide for a group , whilst watching a channel , without having to press down. press main menu, scroll down to "epg" and then select it. There isn't a dedicated button on the remote to access tv guide ? Also the 4 coloured buttons on the remote , red gives a channel lock option , green subtitles option , yellow and blue dont appear to do anything . Can one of these be programmed to open tv guide ?
We will make one of the colored buttons open EPG in an update soon
  • Replies 81
  • Views 8.1k
  • Stugots
    Stugots
    Just to clear this up, BuzzTV G-Series is a certified Google TV device, so the platform and firmware update process is different from our regular Android boxes. There are multiple parties involve
  • Stugots
    Stugots
    What you are describing is an oversimplification of how a certified Google TV device works. This is not a typical AOSP box where one party can freely control and modify the firmware and update path.
Hello i have one problem with subtitles on all my providers on my G-serie buzztv6 some channels have have subtitles and when i choose the subtitle i want it doesnt come up but i know the subtitle is there because on my formuler gtv device is showing up is this an bug or is it something wrong on the player and why can we not choose an another video Player for live just for vod and is it coming an update for subtitles?//Best Regards Alf
Please go here and click start new topic instead of posting in how to section
https://buzztvhelp.com/forum/125-g-series/
The only way I found it possible is to hold the ok button and select categories for now.
The only way I have found is via holding ok button until categories appear.
