BuzzTV6 Application: Wishlist for New Features and Enhancements
Hello We would like to see and it is nice to ad for buzztv 6 EPG server because it is no option in buzztv6 to change EPG to server only in buzztv 5
thanks
  • Replies 192
  • Views 38.3k
  • We're gathering ideas from the BuzzTV community to create a wishlist of new features and improvements for the BuzzTV6 app Your feedback is crucial in helping us understand what features are most
  • Future Feature Request: Mounting and RECORDING/DOWNLOADING to an network shared folder One nice thing to see would be the option to mount an SMB or NFS share (like on a NAS) and use that as a des
  • I just scheduled a recording ,shut box off while I was out. Came back program was recorded properly
thanks
As mentioned in the other thread:
Quote
The P6 currently uses Server EPG on XC Username and Password only
We will add XML support soon
And confirmed 3 posts below that again: "Buzz 6 only uses Server EPG right now"
It is XML that is not there and will be added.
thanks
are you serious?
this isn't isn't the first time you requested something after being told IT WILL BE ADDED!!!
  • 3 weeks later...
it is Nice to see in the Future update picture in picture
  • 3 weeks later...
Group channel numbering and ability to arrang channels how we want in favorites .. theme as well
You can. In fav group press green the options are all there
no u can only do by number by name or postion that they are in cant rearrange or move them to ifferent positions like u can in buzz tv 5
One nice thing to see would be the option to mount an SMB or NFS share (like on a NAS) and use that as a destination for Recordings/Downloads.  Also, if in the same directory or subdirectory it can include whatever file (xml or whatever...) is needed to be able to get the show info (show name, epg description if there was any, channel, etc..).   That way if you have more than one Buzz box, they can point to the same directory, and everyone can share everyone's recordings/downloads.
A huge bonus would be to also have the filenames something more informative (like first 20 characters of show description, followed by date/time of recording).  That way when you look at the directory, you have a good idea of what the media files are.  Right now, they look like random names, but I am sure it has something to do with the stream URL.
Thanks.
Will you be adding a Cloud Recording feature for the Powerstation to be able to record to the Powerstation and connect other BuzzTV Boxes in the house to can record to and watch from like a NVR?
Example house has 5 BuzzTV Boxes and want to record in 1 BuzzTV Box and want to watch later the recording on another BuzzTV Box?
Customize the EPG for live TV as you can with the BUZZ 5 and other player apps  ...
do you even have a powerstation?
since  launch .. do you ?
3 minutes ago, allaboutbuzz said:
Yes it will get added soon
Thank you for your response sir ...
3 minutes ago, Tony 62 said:
good for you
I was just making sure because some members with the L1 think this thread applies to them
Cheers
  • 4 weeks later...
Hello it is possible to ad in VOD and TV series to be able to check the video quality when we press the info button ?
That info is NOT in the movie list provided by the service as far as I know.  So short of downloading/playing part of EVERY single VOD, that would not be possible I'm sure.   Even the movie info/summary is pulled from tmdb/imdb, depending on the movie titles.  So no real way of knowing what version/resolution/quality the file being served by a service is.
when watching it info brings that up
