BuzzTV6 Application: Wishlist for New Features and Enhancements
On 2/10/2025 at 8:13 PM, Blackmagic said:
Will you be adding a Cloud Recording feature for the Powerstation to be able to record to the Powerstation and connect other BuzzTV Boxes in the house to can record to and watch from like a NVR?
Example house has 5 BuzzTV Boxes and want to record in 1 BuzzTV Box and want to watch later the recording on another BuzzTV Box?
yes this is a cool idea for buzz box, actually y have 4 box with tivimate and 1 folder on my truenas NAS (Aoostar WTR Max)
  • Replies 192
  • Views 38.3k
  • We're gathering ideas from the BuzzTV community to create a wishlist of new features and improvements for the BuzzTV6 app Your feedback is crucial in helping us understand what features are most
  • Future Feature Request: Mounting and RECORDING/DOWNLOADING to an network shared folder One nice thing to see would be the option to mount an SMB or NFS share (like on a NAS) and use that as a des
  • I just scheduled a recording ,shut box off while I was out. Came back program was recorded properly
5 hours ago, Padj Bawns said:
Picture in Picture support
if you look at the navigation bar you can see it's planned
I would like to invite the devs to consider incorporating a feature like Game Day on the Formula Z, which aggregates the sporting events and schedules and direct links into a single category for easy browsing and access to live sports. I understand the Formula boxes are more geared toward sports, but with the availability of TV shows and movies from VOD services and news and documentaries on ad-free YouTube, a large percentage of live TV users on all devices are primarily paying for sports. With this reality in mind, perhaps a Game Day category would be appropriate in the Buzz TV 6 live TV app.
I would like to see the ability to use alternative EPG links like MyEPG, etc. with xstream setups, not just with m3u in Buzz TV 6.  I can with TiviMate but you loose the integrated buttons on the remote that only work with the Buzz TV players.
  • 3 weeks later...
Hopefully not missing this anywhere with literally just getting my box yesterday but I would like to be able to see how big my recordings are on the PVR
Hello cyrowth,
I hope you are well. I noticed your post about alternative EPG links. Do you subscribe to My Top EPG service? It provides a URL for Europe and another for Global. Can add two EPG URLs in Tivimate, but not with Buzz Tv 5 or Buzz Tv 6. Did you happen to find a workaround with your Buzz TV Box to add two URLs for the EPG?
Thanks in advance!
  • 2 months later...
Please please give options for the BG of the icons. I just received the brand new Classic Ai model and a ton of my icons are not showing on white background. Transparent , Black or white for options. Thank you so much 🙂
  • 3 months later...
Would be great for the buzztv box to have PiP capability . Not only in the Buzztv app but across the board. Changes in the Manifest values should be Made to support pip windowed apps. Apps in this version of Android 13 always closes or crashed out when trying to go into PiP mode.
the dev's of those apps should add the option
It's not really the apps that is the problem,  I have used the Same apps on a earlier Android box and it worked perfectly. The apps support pip ,but the Powerstation 6 does not support it in the Android 13 version, it only now support it in the buzztv 6 app. The Android TV box itself does not support PIP in the activity or manifest values.
Its supported on our App/Buzz 6 home screen.
We use Google/Android TV are the front end though
Which does not allow PIP on that OS on the official versions of Google TV
The other boxes running AOSP would essentially allow this, but you would be mostly using Mobile apps
