August 9, 20242 yr 1 minute ago, sea157 said: And did it turn itself off after the recording was recorded? it probably didn't turn on
August 9, 20242 yr 18 minutes ago, sea157 said: And did it turn itself off after the recording was recorded? I did the same thing earlier and it recorded and the light remained red the whole time. I just set another recording to start in 7 minutes, and turned it off. I'll go check later and see if it is still off But this has been like that, even on BuzzTV 5 (at least on Android 11 boxes) for quite a while now. The boxes do NOT turn on to record. I have not tried it on my Android 9 devices in quite some time however. This is not something new on Android 13 or BuzzTV 6.
August 10, 20242 yr 33 minutes ago, sea157 said: And did it turn itself off after the recording was recorded? It was off when I got home
August 11, 20242 yr On vod and series notifications of new episodes marked as favorite Series mark as watched when series completed Link buzzrv 6 boxes in same house so can watch series favorites on each box were you left off Improved ease of recording and works Profiles for individual users That's to get me started
August 12, 20242 yr 18 hours ago, Devildog said: On vod and series notifications of new episodes marked as favorite Series mark as watched when series completed Link buzzrv 6 boxes in same house so can watch series favorites on each box were you left off Improved ease of recording and works Profiles for individual users That's to get me started Improved ease of recording and works Please explain
August 13, 20242 yr I would like the ability to rearrange channels once they are added to favourites if possible
August 13, 20242 yr Not sure if this is on the way or not, but I don't see the Backup/Restore config..... This saves a lot of time if you need to do a factory reset.
August 13, 20242 yr 5 minutes ago, sts41 said: Not sure if this is on the way or not, but I don't see the Backup/Restore config..... This saves a lot of time if you need to do a factory reset. it will be implemented soon
August 13, 20242 yr 5 hours ago, DRAG00N519 said: I would like the ability to rearrange channels once they are added to favourites if possible This feature is already there in Organize Favorites Just move them.
August 13, 20242 yr 2 minutes ago, allaboutbuzz said: This feature is already there in Organize Favorites Just move them. Oh really my bad Edited August 13, 20242 yr by DRAG00N519
August 13, 20242 yr 2 hours ago, allaboutbuzz said: This feature is already there in Organize Favorites Just move them. need channel renumbering in config
August 14, 20242 yr On 8/12/2024 at 12:33 PM, dishuser said: talk to your service provider 😉 Nothing to do with service provider
August 14, 20242 yr On 8/10/2024 at 1:00 PM, dishuser said: I would like to be able to adjust picture settings I too would like to be able to adjust picture settings
August 14, 20242 yr 6 hours ago, Devildog said: Nothing to do with service provider User Profiles is a feature we have looked into in the past. Its a lot of work to add this As the Database for it alone is huge. Were still considering it though. Thanks for the suggestion
August 20, 20242 yr would be nice to have the remote turn on the box, wake the TV, and be able to adjust the volume via surround sound system as I have it set up with another box, As it is now I have to use 3 different remotes, one for the box, one to turn on the tv (if I have it set up to turn tv on, then no volume keys on the remote work at all) and the third to work the surround system amp volume. Also if this is at all possible, to have it connect to a lot of diff amp systems, not just newer ones as I really don't want to have to buy a new system . lol Edited August 20, 20242 yr by Jeffrags
August 20, 20242 yr 1 hour ago, Jeffrags said: would be nice to have the remote turn on the box, wake the TV, and be able to adjust the volume via surround sound system as I have it set up with another box, As it is now I have to use 3 different remotes, one for the box, one to turn on the tv (if I have it set up to turn tv on, then no volume keys on the remote work at all) and the third to work the surround system amp volume. Also if this is at all possible, to have it connect to a lot of diff amp systems, not just newer ones as I really don't want to have to buy a new system . lol it's called cec
August 20, 20242 yr I would like to have the back button work the same on Buzz 5 as Buzz 6. Also being able to use the guide button on Buzz 5 ( instead of having to use menu button; then EPG ) otherwise it reverts back to Buzz 6. Also add a "set reminder" button to Buzz 6 guide's record & muti-record button.
August 20, 20242 yr 1 minute ago, kyzursozay2 said: I would like to have the back button work the same on Buzz 5 as Buzz 6. Also being able to use the guide button on Buzz 5 ( instead of having to use menu button; then EPG ) otherwise it reverts back to Buzz 6. read thread title 😉
August 20, 20242 yr 31 minutes ago, kyzursozay2 said: I would like to have the back button work the same on Buzz 5 as Buzz 6. Also being able to use the guide button on Buzz 5 ( instead of having to use menu button; then EPG ) otherwise it reverts back to Buzz 6. Also add a "set reminder" button to Buzz 6 guide's record & muti-record button. What do you mean have the back button work the same on Buzz 5 as Buzz 6? Please explain And the Guide button is a Global button on the Firmware for Buzz 6 only, so it will not work for Buzz 5 Not right now anyhow
August 20, 20242 yr 2 minutes ago, allaboutbuzz said: What do you mean have the back button work the same on Buzz 5 as Buzz 6? Please explain And the Guide button is a Global button on the Firmware for Buzz 6 only, so it will not work for Buzz 5 Not right now anyhow it doesn't work
August 20, 20242 yr 2 minutes ago, dishuser said: it doesn't work Just tried the back button on every menu on Buzz 6 It works no problem.
