Beta Buzz5
  • Replies 107
  • Views 30.3k
    Anyone who took previous Buzz 5 Beta for XR/XRS/MAX 4500 Can now get updated version.  It is mostly fixes based on all of the feedback provided from V20211212 FW + 5.0.642 Anyone who did not ta
  • The second picture shows that 5.0.653 is installed If you didnt get the update how did you get buzz 5 installed?
  • Fastcompany
    Fastcompany
    Sorry. I found exactly the opposite. I. Annoy use secondary. I get “ Unknown Stream Error”. When I use default, I get slow changes (3 to 6 seconds between images) I also find the guide loads VERY slow
1 minute ago, nbs. said:
if you havnt done a hard reset do one
Ok I will do that today is not like I have something to do ,with this snow storm😁
Buzz 5
Last weekend tried so many times to get the beta update finally the box gave me this error.
Some how this box refuse to take it...lol
So I decided to install the IPTV Version 5.0.653 on the old firmware and is working fine...
kind of a "Mix and Match"....
Cheers.
To get the Buzz 5 installed is the easier part of all.
I got it from a different box and installed on this one, but the firmware still the old one
Read the second part of my post.
Cheers.
Cheers.
We updated the MAC lists yesterday for E2s
So your box should get Firmware update for Beta now
I did a reset of both of my xrs4500 ,and still I can't get the secondary player to work on that specific server and some channels from other servers, well I gave up😕,I will leave it like that work only with main player.
