December 24, 20214 yr 2 hours ago, Devildog said: Clients mostly on 4900 and had buzztv 5 before they got a 4900...lol
December 24, 20214 yr Any ETA for the new beta or the new release? The default player is so annoying with this microfreezing frames every few min ,slow to load the picture sometimes looses sound ,I like that on the vod section I can choose an external player 👍, why we don't have that option on the live tv section. On 12/22/2021 at 3:57 PM, nbs. said:
December 26, 20214 yr Author So many comments on clear the picture now with Buzz5 beta file !! xr 4000 xrs 4500
December 26, 20214 yr 3 minutes ago, Rinny1 said: So many comments on clear the picture now with Buzz5 beta file !! xr 4000 xrs 4500 not sure what you mean
December 26, 20214 yr 28 minutes ago, nbs. said: not sure what you mean I think it means he got into the xmas cheer 😉
December 27, 20214 yr the Buzz 5 is out for xrs4500. factory reset then it will download the new Buzz5 and install . version 9 build V20211212.20211212 test-keys
December 27, 20214 yr 3 minutes ago, ger482 said: the Buzz 5 is out for xrs4500. factory reset then it will download the new Buzz5 and install . version 9 build V20211212.20211212 test-keys old news was posted last week
January 11, 20224 yr Anyone who took previous Buzz 5 Beta for XR/XRS/MAX 4500 Can now get updated version. It is mostly fixes based on all of the feedback provided from V20211212 FW + 5.0.642 Anyone who did not take it yet, and are running V20211108 can also get it in Update App. Type in 2015 after the Updater is Open Make sure to Read the Changelog before taking it ----------------------------------------------------------------------------------------- Buzz TV 5 BETA: USE AT YOUR OWN RISK. THERE IS NO WAY TO REVERT BACK. BUGS ARE EXPECTED. PLEASE REPORT ALL BUGS ON STBTALK.COM Jan 11th, 2022 Update Changes: - Fixed Background image bug on Modern Home Screen - Fixed last channel history menu bug - Fixed a PVR Playback bug when not connected to server - Fixed bugs with Downloads for VOD - Fixed Bug with Catch-up not playing on some servers. - Fixed some M3U bugs - Added Sort Feature to TV Episodes list with 100+ Episodes. 0-9/9-0 - Added Navigation on TV Episodes Menu from beginning to end of list/moving left. - Fixed some PVR Bugs - Fixed a bug with Favorite Episodes + Recently watched not being able to press the play button. - Improved Timeshift Performance + a crash bug.
January 12, 20224 yr I still haven't been able to get this or the previous update. I typed 2015 so much I almost wrote it on a document today at work.
January 12, 20224 yr 6 hours ago, allaboutbuzz said: Anyone who took previous Buzz 5 Beta for XR/XRS/MAX 4500 Can now get updated version. It is mostly fixes based on all of the feedback provided from V20211212 FW + 5.0.642 Anyone who did not take it yet, and are running V20211108 can also get it in Update App. Type in 2015 after the Updater is Open Make sure to Read the Changelog before taking it ----------------------------------------------------------------------------------------- Buzz TV 5 BETA: USE AT YOUR OWN RISK. THERE IS NO WAY TO REVERT BACK. BUGS ARE EXPECTED. PLEASE REPORT ALL BUGS ON STBTALK.COM Jan 11th, 2022 Update Changes: - Fixed Background image bug on Modern Home Screen - Fixed last channel history menu bug - Fixed a PVR Playback bug when not connected to server - Fixed bugs with Downloads for VOD - Fixed Bug with Catch-up not playing on some servers. - Fixed some M3U bugs - Added Sort Feature to TV Episodes list with 100+ Episodes. 0-9/9-0 - Added Navigation on TV Episodes Menu from beginning to end of list/moving left. - Fixed some PVR Bugs - Fixed a bug with Favorite Episodes + Recently watched not being able to press the play button. - Improved Timeshift Performance + a crash bug. I did the update ,yes those mentioned are fixed ,but the problem with the secondary player that gives the error stream not available is still there 😒, secondary player is useless for now😒
January 12, 20224 yr The default player still plays with microfreezing and lower frames 😒,I miss secondary player 😒, well maybe the next update 😕
January 12, 20224 yr 47 minutes ago, Nelutz said: I did the update ,yes those mentioned are fixed ,but the problem with the secondary player that gives the error stream not available is still there 😒, secondary player is useless for now😒 I just took the update on my xrs 4500 and have no issues using secondary player
January 12, 20224 yr majority of my last channels are from my favorites yet when I pick a channel it takes me to the channel showing the category it came from not favorites
January 12, 20224 yr 34 minutes ago, dishuser said: I just took the update on my xrs 4500 and have no issues using secondary player I don't know what server you use but I use 3 different servers and the secondary player doesn't work for me,Im curios what server you use 😕.
January 12, 20224 yr 23 minutes ago, dishuser said: against rules You could send me a private,just curios, plus even with the default player I'm loosing the sound on some channels ,I have to change the channel and come back to get the sound 😕
January 12, 20224 yr Author Secondary player awesome 😎 on live tv channels secondary a no go on VoD but default no problems
January 12, 20224 yr 11 hours ago, Nelutz said: I don't know what server you use but I use 3 different servers and the secondary player doesn't work for me,Im curios what server you use 😕. If you're using XC login Do the following. Press Menu Go to Configuration At bottom change Stream from TS to HLS. Reconnect to server. The channels should start working on secondary.
January 12, 20224 yr 15 hours ago, Nelutz said: You could send me a private,just curios, plus even with the default player I'm loosing the sound on some channels ,I have to change the channel and come back to get the sound 😕 After the update i just get a black screen
