Beta Buzz5
8 hours ago, nbs. said:
but the same server works for me
I understand nbs because it was working fine for me on E2 too but 4900 never worked for months until server people did something and started to work on 4900.
  • Replies 107
  • Views 30.3k
    Anyone who took previous Buzz 5 Beta for XR/XRS/MAX 4500 Can now get updated version.  It is mostly fixes based on all of the feedback provided from V20211212 FW + 5.0.642 Anyone who did not ta
  • The second picture shows that 5.0.653 is installed If you didnt get the update how did you get buzz 5 installed?
  • Fastcompany
    Fastcompany
    Sorry. I found exactly the opposite. I. Annoy use secondary. I get “ Unknown Stream Error”. When I use default, I get slow changes (3 to 6 seconds between images) I also find the guide loads VERY slow
😕 Anyway ,it might be the device maybe I have to do a reset ,but is such a husle to type back all the servers 😕
do a backup first
3 minutes ago, dishuser said:
do a backup first
Doesn't want to take it 😕 gives me error
Just tried backup on mine to USB ,seems to be working
Yeah is doing the same to me and I was waiting for 3 hours than I give up, btw I have a lot of restarts on the buzztv app when it shows me stream not available than the app restarts😕
mine backed it up
mine works flawless and made a back up as well.
you have a 4500?
12 minutes ago, nbs. said:
you have a 4500?
oops sorry 4900.
but few friends have 4500 and few have 4000 and no complaints 🙂
they all have servers I got and they all made their backups and has been working rock solid since day one.  few are testing buzz 5 and love it so far. not all updated due to nature of some of them 🙂
Wow ,so something is wrong with my 4500
You still haven't said that you did a reset
41 minutes ago, Ryu said:
oops sorry 4900.
so you did a backup on your 4900?
no. 4500  and 4000 for someone 🙂
since you are unable to create back up, and stream is not available, I think you downloaded something that caused some issues.
reset is the best and fast way to resolve your issues. if you ever decided to reset then after reset dont download additional apps. just test server and make a back first. then later when you download your apps and if issue arise then you know which app is causing issues. 🙂
Valid point…
Yes I did a reset , ofcorse with out back up, and after 30min I put back all my apps and servers, but the problem with that specific server that doesn't work with secondary player is still there ,I don't know how is working with you  because like I said I have two xrs4500 and both not working with secondary player on that server I've change it the stream to HLS still the same problem 😕"stream not available"
Yes I did that ,still the same problem on both xrs4500😕 ,is working on other servers but on that server is like I have to use the primary server to see the picture.
Edited by Nelutz
but does it work on default player?
Yes is working with the default player😕 , weird because before this new buzztv 5 ,with the 4 I never had any issues with any server on the secondary player 😕
I did and on one service I had to use default
but now they all work with secondary for me
Hmm ,maybe I have two xrs4500 that are broken?because it can be a problem with one but both are not working with that server , tomorrow I will try it on another xrs4500 to see if is true ,I will provide you with another log in that server and I want if possible to you to take a shot video an show me that is working on yours?
I have had mac addys that had to be removed and added back to server to work
I could have easily taken video of your server working with your trial You doubt my word that it worked???
So you did a soft or hard reset
I would do a hard reset if I were you
No is not like that I have doubt in what you saying,but is weird because I have two xrs and both have the same problems and I do all the steps to make it work but it doesn't maybe I do something wrong or I miss something 😕, plus now if I stay in a channel that it shows me stream not available for 5-10 sec the app restarts and push me to the home screen 😕
Edited by Nelutz
