Problem after update
My Classic box is acting up after the new update. The box is buffering a lot now.
 I have factory reset it but the new update is still there.
What can be done?
When you say factory reset, did you do a HARD (using PIN method) or SOFT (just through the menus) reset ?
If you did a soft reset, do a HARD RESET.
Same as this procedure:
https://stbtalk.com/topic/300-factory-reset-hard-reset-xr4500-xrs4500/
On Classic you can use the button that is on the side of the box instead of sticking pin in the A/V hole.
Also, if you have Timeshift enabled or any of the other options (like RealTime streaming, etc..) turn them off.
What can be done?
Factory Resetting a box that already took an update
Will always re install the current version you're running. There is no way to revert back to the previous version
Try running Analiti app tests and make sure your -db rating is good for signal + your speeds.
Good afternoon Emporium. Regarding your comment for the Classic, do you mean that holding the side button and plugging in the power will bring you to the Android screen we would see with the pin reset method?
E5 Model works the same way also.
