July 18, 20242 yr 11 hours ago, dishuser said: there's plenty of good exteral drives out there for less I was thinking there were probably cheaper options available but a friend recommended that particular SSD end it was also the one I seen when scrolling through the pictures for the power station so I figured why not go with that one because I know it's compatible with the device
August 3, 20242 yr Author Hi All, I believe the Powerstation is available very soon, would there be any possibility of sharing images of 'server settings' and how to load portal. Many Thanks
August 3, 20242 yr 37 minutes ago, TonyC said: Same as the xrs 4900? all are the same for server settings
August 3, 20242 yr 4 hours ago, TonyC said: Same as the xrs 4900? The 4900 never had buzztv 2 🙂 But the truth is, since buzztv 2 the options have not changed that much. On Buzztv 2, you had a certain number of "slots" available (I think it was 13), and you had only 3 reserved for M3U lists. As of BuzzTV 4 (which has carried over to BuzzTV 5) it changed and you have 3 separate options (MAC/XC/M3U) and you can add as many server entries as you want in each sub type. And in a recent update (few months ago), they added back the option to be able to change MAC on BuzzTV 5. BuzzTV 6, there is rumour that you may have more than one server active at the same time (similar to another popular software), but since no one has seen it yet (at least not anyone who is not bound by any NDA), it is hard to provide details. If they shipped yesterday, then people should start receiving them this coming week. Not sure if they will have buzztv 6 or if buzztv6 will be an OTA update, but I guess we'll find out soon enough.
August 3, 20242 yr changing mac happened last year the power station comes with buzztv 6 hence the code name p6 😉
August 8, 20242 yr It's not how they want it right now but they don't wish to hold things up I'm not at liberty to discuss finished product Sorry
August 8, 20242 yr 4 hours ago, TonyC said: Hi NBS, How will it change? Many Thanks Its already changed, we had a different UI on an internal pre release So we changed it based on feedback and its ready to go right now for the release
