August 28, 20233 yr Author V.890 Beta update is out however there is a bug using it on the XRS4900 when performing a Backup to an external thumb drive. The U5 is not affected, selections are saved to the Root of the selected drive by choice. The U5 Firmware has a new update in addition to the App software .890
August 28, 20233 yr 14 minutes ago, tvlarry said: V.890 Beta update is out however there is a bug using it on the XRS4900 when performing a Backup to an external thumb drive. The U5 is not affected, selections are saved to the Root of the selected drive by choice. The U5 Firmware has a new update in addition to the App software .890 Appreciate you sharing this, but it is WAY off topic. That should have been in a thread of it's own (assuming we allow beta discussions here). This has nothing to do with player selection 🙂
August 29, 20233 yr Author Thanks Dish, the Firmware and Buzz Beta took care of those Player issues. I noted the Backup issue only for reference. IN the future I will start another Post for these updates, but in this case when using a certain Provider, some channels would not appear using the Main Player. ] Edited August 29, 20233 yr by tvlarry
August 29, 20233 yr 15 minutes ago, tvlarry said: Thanks Dish, the Firmware and Buzz Beta took care of those Player issues. I noted the Backup issue only for reference. IN the future I will start another Post for these updates, but in this case when using a certain Provider, some channels would not appear using the Main Player. ] An update went out today to fix channel issues on xc servers Edited August 29, 20233 yr by nbs.
August 30, 20233 yr 2 minutes ago, tvlarry said: Great News ! you should have got it yesterday morning I did
August 30, 20233 yr On 8/29/2023 at 12:22 PM, tvlarry said: Thanks Dish, the Firmware and Buzz Beta took care of those Player issues. I noted the Backup issue only for reference. IN the future I will start another Post for these updates, but in this case when using a certain Provider, some channels would not appear using the Main Player. ] backup only worx to internal not external since it's not the same OS as the u5
