June 14, 20224 yr On 6/9/2022 at 2:41 PM, Mark M said: Sorry for the delay getting back to you...I'm in the process of packing to move. It only seems to happen with TS on. Can you PM me As we have been testing and trying to reproduce this issue But cannot so far So need some more details
June 14, 20224 yr On 6/9/2022 at 7:01 PM, Goonloco said: Same is happening to me on my xrs4900 when timeshift is on. Can you PM me As we have been testing and trying to reproduce this issue But cannot so far
June 15, 20224 yr Author 23 hours ago, allaboutbuzz said: Can you PM me As we have been testing and trying to reproduce this issue But cannot so far Just did. Thx!
July 5, 20224 yr Hi, So when it’s removed will there be an option to make sure that it’s the USB or SD card that is being used for the timeshift. Also, I’m hoping that if the option is removed that the pause, rewind and fast-forwarding will still work as that is the reason I purchased this box?
July 5, 20224 yr 5 hours ago, bigivy said: Hi, So when it’s removed will there be an option to make sure that it’s the USB or SD card that is being used for the timeshift. Also, I’m hoping that if the option is removed that the pause, rewind and fast-forwarding will still work as that is the reason I purchased this box? who said it was being removed?
July 5, 20224 yr Author 26 minutes ago, dishuser said: who said it was being removed? Does this look familiar? allaboutbuzz Moderators 786 Posted June 6 On 6/6/2022 at 11:41 AM, Mark M said: I didn't say you did...I was asking. Timeshift is on, and storage location is internal shared storage, which has 115GB free space Using Internal Storage for timeshift is a bug on Android actually It requires a lot of space to use it. We will be removing it as an option in a future update If you want to use Timeshift its best to use a USB or SD Card.
July 5, 20224 yr Pretty sure the "We will be removing it as an option" was referring to the option of using internal storage. If you want to use TS you will eventually need some sort of external storage. This was not referring to the option of TS entirely. Using Internal storage is also unnecessary wear and tear on the internal storage. External storage can easily be replaced if it eventually fails, internal you don't want to use for this kind of activity. Edited July 5, 20224 yr by Emporium
July 5, 20224 yr Author 23 minutes ago, Emporium said: Pretty sure the "We will be removing it as an option" was referring to the option of using internal storage. If you want to use TS you will eventually need some sort of external storage. This was not referring to the option of TS entirely. Using Internal storage is also unnecessary wear and tear on the internal storage. External storage can easily be replaced if it eventually fails, internal you don't want to use for this kind of activity. That's exactly what it was referring to, as clearly evidenced by the pasted quote from June in my post above you.
July 5, 20224 yr 9 minutes ago, Mark M said: That's exactly what it was referring to, as clearly evidenced by the pasted quote from June in my post above you. read what I quoted they posted that they hope sd card will still be an option no one said that option will be removed
July 5, 20224 yr Author 2 hours ago, dishuser said: read what I quoted they posted that they hope sd card will still be an option no one said that option will be removed No he/she didn't. They said "...option to make sure that it’s the USB or SD card that is being used". They wrote nothing about the SD card being removed as an option. Edited July 5, 20224 yr by Mark M clarification
July 5, 20224 yr 8 hours ago, bigivy said: So when it’s removed will there be an option to make sure that it’s the USB or SD card that is being used for the timeshift. 3 minutes ago, Mark M said: No he/she didn't. They said "...option to make sure that it’s the USB or SD card that is being used". They wrote nothing about the SD card being removed as an option. is that right?lol allaboutbuzz never said that won't be an option is my point so why ask Edited July 5, 20224 yr by dishuser
July 5, 20224 yr 43 minutes ago, dishuser said: is that right?lol allaboutbuzz never said that won't be an option is my point so why ask We have decided to leave Internal. memory for TS for now As we fixed a bug with it not allowing it to be used/saying not enough storage available. And optimized it more when using it.
July 5, 20224 yr 5 minutes ago, allaboutbuzz said: We have decided to leave Internal. memory for TS for now As we fixed a bug with it not allowing it to be used/saying not enough storage available. And optimized it more when using it. I have to thank you here as I've used my allotment for the day...lol
July 5, 20224 yr 3 hours ago, Emporium said: Pretty sure the "We will be removing it as an option" was referring to the option of using internal storage. If you want to use TS you will eventually need some sort of external storage. This was not referring to the option of TS entirely. Using Internal storage is also unnecessary wear and tear on the internal storage. External storage can easily be replaced if it eventually fails, internal you don't want to use for this kind of activity. Yes definitely not removing it entirely Sorry for the confusion
July 5, 20224 yr 8 minutes ago, dishuser said: I have to thank you here as I've used my allotment for the day...lol Yes sorry about the confusion
July 5, 20224 yr Just now, allaboutbuzz said: Yes sorry about the confusion I wasn't confused others were though 😉
July 6, 20224 yr Hi, Thanks for the replies. As a footnote to this subject. I plugged my external USB into my computer and used the"treesize" program to see what was using up the space and was quite surprised to find that it had around 8 GB of a cache from the time shift and I don't think that I had used it that much pausing etc as I've only had the Buzz box a few days, so I can see why it's recommended to use an external USB for the time shift
July 6, 20224 yr 30 minutes ago, dishuser said: you can set cache size Hi, Thanks for the reply. I knew about setting the cache limit, I have mine set for 10 gb, I was just surprised how large the cache was considering I've not used the time shift feature that much,well I didn't think I had,lol. So what happens when the cache size reaches the 10 gb limit and is there a way to empty the cache, apart from hooking the USB to the computer and clearing the cache that way?
July 6, 20224 yr I could be wrong but I think it clears itself when it reaches limit and starts over allaboutbuzz will know though
July 6, 20224 yr 2 hours ago, bigivy said: Hi, Thanks for the reply. I knew about setting the cache limit, I have mine set for 10 gb, I was just surprised how large the cache was considering I've not used the time shift feature that much,well I didn't think I had,lol. So what happens when the cache size reaches the 10 gb limit and is there a way to empty the cache, apart from hooking the USB to the computer and clearing the cache that way? Use this as a rule of thumb for cache size 1GB of Cache is equal to about 30-60 Mins of Live TV for TimeShift, depending on channel quality So 10GB would be 5-10 Hours And yes it overwrites itself once the cache fills up.
July 7, 20224 yr 12 hours ago, allaboutbuzz said: Use this as a rule of thumb for cache size 1GB of Cache is equal to about 30-60 Mins of Live TV for TimeShift, depending on channel quality So 10GB would be 5-10 Hours And yes it overwrites itself once the cache fills up. Ah I see, good to know. Thank you for the info 👍👌🙂
June 30, 20233 yr 10 minutes ago, randy said: What does the timeshift do is it necessary do you watch sports? do you go to the bathroom and miss a goal or touchdown and wish you could have saw it?
