Timeshift error
a new bug that i noticed when using time shift is that every time it hits the top of the hour it freezes for like 20-30 seconds every time,
using a x5 box.
  • Replies 54
  • Views 19.9k
    Use this as a rule of thumb for cache size   1GB of Cache is equal to about 30-60 Mins of Live TV for TimeShift, depending on channel quality   So 10GB would be 5-10 Hours And
  • dishuser
    dishuser
    I wasn't confused others were though 😉
  • Worked like a charm. Thanks so much for your help!!
using a x5 box.
Post more info
like what? all i noticed is that it happens when time shift is on. every top of the hour it freezes. using a usb flash drive.
Since it's not a reported issue any info is better than nothing
What type usb,formatted?
Dies it happen when you are not using it?
