October 23, 20241 yr 41 minutes ago, Chris1 said: I have what the latest update was for did you go into settings of disney app?
October 23, 20241 yr 1 hour ago, dishuser said: 2.2.0 is 3 years old 3.8.0 is weeks old Did you READ my message? I don't care about the version of the DISNEY app. If you launch the DRM info app on the P6, on the RIGHT hand side, it mentioned max level of HDCP supported (which is 2.3) and "current" HDCP version. What is the CURRENT. This will be dependant on the whole hardware loop you have (from box, any receiver/soundbar/to the TV). Even cable can affect it. The Disney app is picky. If it doesn't get reported all the proper DRM to ensure copy protection is in place, it will default to 1080. Edited October 23, 20241 yr by Emporium
October 23, 20241 yr 13 minutes ago, Emporium said: Did you READ my message? I don't care about the version of the DISNEY app. If you launch the DRM info app on the P6, on the RIGHT hand side, it mentioned max level of HDCP supported (which is 2.3) and "current" HDCP version. What is the CURRENT. This will be dependant on the whole hardware loop you have (from box, any receiver/soundbar/to the TV). Even cable can affect it. The Disney app is picky. If it doesn't get reported all the proper DRM to ensure copy protection is in place, it will default to 1080. I thought you meant the disney version anyways mine loads instantly and I'm out since I don't pay for disney...lol
October 23, 20241 yr Well if "max" and "current" also says 2.3, then I have no clue what else to check. I no longer pay for Disney either, so I can't go any further, so I'm out.
October 23, 20241 yr Author I finger out what the problem is the one on the last update is the andoid mobile one and not the andoid tv one that why it's only doing hd not 4k can a update be can there a update with the andoid tv one
