Bugs and known Workarounds
39 minutes ago, sts41 said:
Funny, mine is the opposite, I can get connected to Buzztv 6 but BuzzTV 5 gives error that incorrect username and password. I am using MAC with no need for User or Pass. I am able to connect to Buzz5 on my older 4500 box. With all the bugs, I would really like to be able to connect to Buzz 5 for the next month or so. Unfortunatly, I sold the 4500 and it is now gone... I think that was premature. 🙂
just curios did you perform a rest on provider side before switching back to buzz5? If not then try that first.
  • Replies 109
  • Views 29k
    Some issues reported on here have already been fixed on OTA updates Anything outstanding has been reported, and when fixed will be mentioned in our change logs for OTAs   Thanks for everyo
  • There will be an update shortly which fixes most server issues
    Bugs 1,2,4 have been fixed on V1.0.30   Will do Bug #3 and your feature request next week
No, I did not go back to provider since It worked on P6 and my old Buzz 5.... Am I assuming correct that rest = reset? I will explain the situation to them, maybe they can also come up with a way I can jump back and forth.
19 minutes ago, dishuser said:
are you accessing catchup from bottom toolbar(options)?
No.... just EPG, lookup show and press enter. I will try and see if that works
It worked, This is great... I am mostly back up and running, or at least crawling 🙂 but that was a big step.
30 minutes ago, Terry mah said:
Ok thanks.did yours pair automatic or did you hold ok and home button
Held buttons
54 minutes ago, Terry mah said:
Still cant get mine to pair 😭😭
On the BT 500 you can try factory resetting the remote first
By holding down the
0+down button for 5 seconds. It should blink 3x to confirm its been reset
Then you can long press the info button while pointing the remote at the box to bring up the pairing animation.
1 minute ago, Terry mah said:
My P6 is stuck here never got any further from first turning it on
So pairing the remote here doesn't work at all?
You can also press the back button to exit this and just use the remote as IR for now to go through the welcome screen
I did back button asked if I wanted to cancel Bluetooth pairing I clicked yes and now just back to black screen 😭
Try unplugging the box from electric for about 30 seconds, the plug it back in and let it reboot.
This always seems to help me when I have problems like that.
I noticed in live tv with P6 that there are a whole row of options missing, change player etc. P5 works fine all options are there. i have the latest update 809. no problem works great very fast response.
Yes we will be adding all of the Configuration options in future updates to Buzz 6
