May 17, 20242 yr 5 minutes ago, dishuser said: found 17 star trek without using : Lol.. Sure you can find them (never said you can't). But if you have a service like the OP, which has dozens of each movie, you can use the ":" to narrow it down to a specific movie. There is always a way around it. Guess the search box could also be completely converted as an input and use the default google keyboard popup for input. That would allow people the flexibility to just configure their google keyboard and search in whatever character set they want.
May 17, 20242 yr Jmo there will always be someone complaining that it might take an extra 30 seconds to find a show
May 17, 20242 yr 22 minutes ago, Emporium said: Lol.. Sure you can find them (never said you can't). But if you have a service like the OP, which has dozens of each movie, you can use the ":" to narrow it down to a specific movie. There is always a way around it. Guess the search box could also be completely converted as an input and use the default google keyboard popup for input. That would allow people the flexibility to just configure their google keyboard and search in whatever character set they want. 23 minutes ago, Emporium said: Lol.. Sure you can find them (never said you can't). But if you have a service like the OP, which has dozens of each movie, you can use the ":" to narrow it down to a specific movie. There is always a way around it. Guess the search box could also be completely converted as an input and use the default google keyboard popup for input. That would allow people the flexibility to just configure their google keyboard and search in whatever character set they want. all 17 had : after star trek
May 17, 20242 yr 5 hours ago, Emporium said: The "_" you don't see much in titles. But the ":" is quite common in movies with sequels and franchises.. Just search for "Star Trek" or "Star wars" and you will see many of them have a ":" to separate the Franchise name, from the specific movie title. We will add : in place of the doubles for *
May 29, 20242 yr 1 hour ago, dishuser said: and the changes were made in 5.0.932 Had my glasses off..lol
May 29, 20242 yr 15 minutes ago, nbs. said: Had my glasses off..lol ya I had to look at the keyboard for a few minutes...lol
