June 1, 20233 yr Author Hi, I have a new problem after I started the other player. I do no have the time shifts anymore.??
June 1, 20233 yr 2 hours ago, Gilles1945 said: Hi, I have a new problem after I started the other player. I do no have the time shifts anymore.?? time shift works only on primary player but if your server offers catchup then you can use that instead of time shift
June 1, 20233 yr you can see catch up symbol while playing channel, press info button and you will see play button inside of almost complete circle symbol before TS so press right arrow and pick up previous program that you want to watch and hit ok. Edited June 1, 20233 yr by Ryu
June 1, 20233 yr it also appears when you press ok to show channel list or when you press guide button
June 11, 20233 yr Author A new problem incurring on both players and event after clearing the cache. I do not know if it's the provider or the BuzzTV X5. The screen jumped see the short video. 20230611_084133.mp4
June 11, 20233 yr try to remove hdmi cable from both ends then try again, also try different hdmi cable if available
June 11, 20233 yr First of all, next time I would strongly recommend starting a new thread if it is for a different problem. For the benefit of other users who search for solutions to their problems, it always helps if a thread stays on topic, and doesn't change directions 20 times 🙂 Having said that, I agree with Ryu. From the quick glimpse at the video, this looks like an HDMI cable issue. If you have another cable, I'd suggest trying to swap it. And if that doesn't help, maybe try using a different HDMI input on your TV.
June 11, 20233 yr Author Thank you very much to both of you. I regret that I post not to a new thread. If you can move it to the right place I would appreciate that if possible. Right now I'm in camper and I will be home the 15th June. So I will check that out. Appreciate very much your help, we need your knowledge. Regard Gilles
