May 9, 20233 yr At first everything was OK and the error is that I went to storage and clicked to sd card and there we go. The sd card is in the slot and it's not recognize by X5. Other than reset is there a bathers way to recognize the card? Please help 🙏
May 10, 20233 yr Author Thanks Ryu, I couldn't format from my computer it wasn't working but I did it with my Smartphone and it worked. Thank you very much
May 23, 20233 yr Author Hi Ryu everything was working fine until today. Know I'm getting this message. Timeshift error. Stream is not available on USA and Canada channel but it's working on France channels . My VPN is on. Thanks for helping
May 23, 20233 yr Author You are right I just received an email from my provider that they are down apparently it's servers problem. Thank you so much Ryu.
May 31, 20233 yr Author Starting with new provider What could be the problem I have refresh the BuzzTV X5 and also clear the cache. And still get pictures free for a really short time like a hiccups.
May 31, 20233 yr Author Sorry for my English I get freez images it freez for very showtime like a flash but often times
May 31, 20233 yr Author I have the media player of the BuzzTV X5 can I have another player running on BuzzTV x5
May 31, 20233 yr 2 minutes ago, Gilles1945 said: I have the media player of the BuzzTV X5 can I have another player running on BuzzTV x5 Menu ,settings, configuration There are two media players
May 31, 20233 yr Author Is it what you're talking about primary and backup?? And what would be the best choice for buffer time??
May 31, 20233 yr Author Thanks Ryu. but there are 2 media player so instead of default what is the other one?
May 31, 20233 yr 25 minutes ago, Gilles1945 said: Thanks Ryu. but there are 2 media player so instead of default what is the other one? Just look ,there have been changes to the player names Edited May 31, 20233 yr by nbs.
May 31, 20233 yr Just now, Gilles1945 said: OK thanks you so much I'm going to change to backup if that doesn't fix it then it could be your speed,isp throttling or service is crap
