August 9, 20224 yr Keep getting this error after watching vod and switching back to live tv. Have to refresh server inorder to get it to go away
August 9, 20224 yr I have seen this only once on one server (don't recall server name, randomly picked from online lol) and that happened only on few channels.
August 9, 20224 yr I typically used to go to home screen before clicking on LiveTV, but I just tried it and reproduced it consistently with 758 also. However I did notice one interesting thing.. If I go to VOD and then select "resume" on something I was watching, instead of "Play" to start over, then the error does not occur when switching back to LiveTV. But if I select "Play" (could be on same title), then after a few second switch back to LiveTV it will always give me this error. I tried with at least 3 different channels set on my LiveTV to see if it was specific channel initialization which caused it, and didn't make a difference on which channel I was tuned to on LiveTV when it switched back.
August 9, 20224 yr 1 hour ago, Emporium said: I typically used to go to home screen before clicking on LiveTV, but I just tried it and reproduced it consistently with 758 also. However I did notice one interesting thing.. If I go to VOD and then select "resume" on something I was watching, instead of "Play" to start over, then the error does not occur when switching back to LiveTV. But if I select "Play" (could be on same title), then after a few second switch back to LiveTV it will always give me this error. I tried with at least 3 different channels set on my LiveTV to see if it was specific channel initialization which caused it, and didn't make a difference on which channel I was tuned to on LiveTV when it switched back. How do you switch to Live TV from VOD using Live TV button on remote or pressing back multiple times And which players are setup in Live and VOD
August 9, 20224 yr We can randomly reproduce this issue if use VLC/Backup Player in VOD and Primary in Live TV, and switch from VOD to Live TV by pressing LIve TV Button on remote now trying to figure out why it happens and fix it
August 9, 20224 yr Author I go to live tv by pressing live tv button and it happens with the primary player
