October 2, 20224 yr 6 minutes ago, Ryu said: they both do the exact same. pick according to your budget 🙂 they're the same price
October 2, 20224 yr 5 minutes ago, dishuser said: they're the same price x5 64 gb and 128 gb same price as 4900
October 2, 20224 yr 2 minutes ago, Ryu said: x5 64 gb and 128 gb same price as 4900 you said they do the exact same obviously 64 is not the same
October 2, 20224 yr 6 minutes ago, dishuser said: you said they do the exact same obviously 64 is not the same they were asking for recording and functionality lol specs wise X5 has upper hand 🙂
October 2, 20224 yr 40 minutes ago, Ryu said: they were asking for recording and functionality lol specs wise X5 has upper hand 🙂 128gb holds a lot more recording than 64gb...lol
October 3, 20224 yr True but the 4900 has the advantage of being able to add an internal 2.5" HDD/SSD (like the U5), making it ideal and a lot neater for those recording large amounts (or downloading VOD locally). I installed a 256GB SSD initially, now replaced it with a 1TB SSD in my 4900 and it works quite well. Don't need to use internal storage for recordings, and neither a USB key. But in terms of CPU power, yes the X5/U5 have the advantage. But keep in mind that the X5 and U5 are newer, so there may be a few little glitches initially, but Buzz is addressing them quickly as they appear, as usual. The 4900 however is getting harder and harder to find. Buzztvglobal canada site no longer lists it, and neither on amazon canada (direct from buzz).
October 3, 20224 yr 17 minutes ago, Emporium said: True but the 4900 has the advantage of being able to add an internal 2.5" HDD/SSD (like the U5), making it ideal and a lot neater for those recording large amounts (or downloading VOD locally). I installed a 256GB SSD initially, now replaced it with a 1TB SSD in my 4900 and it works quite well. Don't need to use internal storage for recordings, and neither a USB key. But in terms of CPU power, yes the X5/U5 have the advantage. But keep in mind that the X5 and U5 are newer, so there may be a few little glitches initially, but Buzz is addressing them quickly as they appear, as usual. The 4900 however is getting harder and harder to find. Buzztvglobal canada site no longer lists it, and neither on amazon canada (direct from buzz). wws still has them
October 3, 20224 yr Just now, dishuser said: wws still has them Completely forgot about them. I had bought my first xpl3000 from them 🙂
October 3, 20224 yr 11 minutes ago, Emporium said: Completely forgot about them. I had bought my first xpl3000 from them 🙂 compare the 2 addresses...lol
