August 6, 20224 yr 1 hour ago, Emporium said: You sure about that ? Even in your post above you stated "with 2 connections you use both while recording the channel you're watching" and this is what I recall when running a few tests back then. ya I'm sure since I checked before posting edit time is really low here so I couldn't correct that post and I just checked again menu/settings/account info and it shows 1 connection being used same as in panel
August 8, 20224 yr If I am recording a show, then decide to start watching it , say, half way through, would I need at least 2 connections to do this? TK
August 8, 20224 yr 33 minutes ago, Terry Knapper said: If I am recording a show, then decide to start watching it , say, half way through, would I need at least 2 connections to do this? TK no you just need 1 connection and make sure TS is enabled and setup properly. 🙂 Edited August 8, 20224 yr by Ryu
August 15, 20224 yr I'm new to Buzztv and Im using iptv. How do I load Typhoon into mac server or api login? Or what iptv/ m3u list is everyone using and how do I load it thanks Tim.
August 15, 20224 yr Hi @TimothyJ First rule, is we do not mention specific servers in these forums, since we do not promote any particular server. Not sure this specific server even offers MAC or M3U/XC api login. If it is the one I think it is, from their FAQ, they say: "No, we do not [support 3rd party apps, like smarters, or anything else]. Our app is built from scratch. We do not support 3rd Party apps. You can use the service with xxxx Streaming app only". Which means the only option they give you, is to download their app, and use that on an android box. Which means you would NOT be using the BuzzTV5 app for this service. You can install the app on the Buzz box and use it, but you will not benefit from any BuzzTV 5 app features. Typically It all depends if you have a MAC based subscription, or an username/password type subscription. If you have a MAC type subscription, you need to give your "SERVER ID" [00:1A:79....] to your reseller, and they need to ensure that that is the MAC address associated to your subscription. In that case, you would need to create a new MAC server, and all you need to do is enter the portal URL you were given by your reseller. If you have a username/password type, odds are you have an XC api type login, so you would create an XC code server, then enter the portal URL you were given by your reseller, and then the username/password you were given or chose. Many/most services will offer MAC or XC api type logins. Edited August 15, 20224 yr by Emporium
August 15, 20224 yr you're not allowed to mention service names here how you decide which server option you use depends on what your service gave you
