buzz tv and is there a step by step on how to record
hey Guys
i’m having a problem recording with my buzz box v5
is there a step by step on how to record programs to it?
i’m hit and miss,some of my questions are
do you have to leave the box on? and on the channel you want to record?
can you record to a usb or sd card?
can you use sd card and/or usb to record channels and also use the same card or usb to timeshift?
do i have to leave it on the iptv provider to record or can i watch one of the two i have and will it record on the the one i’m not watching at the moment?
what’s the best place to store timeshift data?
i know…lol alot of questions and i’m testing when i have time but it’s warm outside so the fam is demanding of my time right now
thx and Troy is the freakin man!!
a lot depends on whether your service allows one connection or more
Menu ,account info will tell you if there is more than one
one service allows 2 the other allows 4 but it seems like if i record a show while box and reciever are on and tuned to the channel i want to record? it works but that doesn't seem right to me
shouldn't i be able to put the box to sleep and the reciver off and still have it record?
anyone else recording iptv using the buzz app have sucess?
how are you doing it?
thx
recording and turning off box works on 4900
ill play with recording tonight on the x5
i did record two shows and watch while watching one channel
One of the recordings failed but one worked
You can hit the red button to start recording immediately I use one button record
you can record from guide and either schedule it Always good to add a few minutes
Then you can schedulea recording from menu etc
same
also when I was watching the channel I was recording it was freezing quite a bit but the recording is flawless
I figured out why it failed
you need more than 2 connections
with 2 connections you use both while recording the channel you're watching
just tried a server with 4 connections and can do 2 recordings at same time
 it still causes freezing but recordings are flawless
10 minutes ago, nbs. said:
i have 3 connections when that failed I will be trying again
I had 2 recordings going and watched a different channel
maybe I should push the envelope and add a download at same time 🙃
if it worx I'll see if I can get the log from service
one recording while watching = 2
two recordings while watching one = 3
three recordings while watching one = 4
but I can watch a channel other than the ones recording and it stays at 4
and freezing has improved greatly
one button record is off
  • 3 weeks later...
I’m just bought a new  xrs4900 my question is can I record my favourite movie but on schedule time I mean the stb is off I tried to record when the stb is off but it is not working Can somebody help me.  Thanks
Hit menu ,what is version number at bottom?
you need an update
pm allaboutbuzz or email cs@buzztv.com your mac addy(server id),model number and current version
pm allaboutbuzz and ask for autoupdate
also load this pvr file
https://www.mediafire.com/file/epmf5i0suejl6rj/com_buzz.services.pvr_33_5056428e-2cad-4bbe-9a31-4e13bdb55857.apk/file
  • 4 weeks later...
1 hour ago, Terry Knapper said:
By , say , four connections, do you mean the same playlist from a supplier that
allows multiple connections?
Terry K
YES, that is exactly what he is referring to.
Some suppliers offer multiple connections (2, 3,  4 or more).  This will allow you to do multiple recording in parallel.  Just keep in mind that each recording is a fork and creates another connection to the server.  So watching live TV is one connection and then every simultaneous recording (even if it is the same channel you are watching) is another connection.
watching and recording same channel is one connection
You sure about that ?
Even in your post above you stated "with 2 connections you use both while recording the channel you're watching" and this is what I recall when running a few tests back then.
