Need help to set up closed captions on Buzz Tv classic AI
Hi, I have a new buzztv Classic AI , and I want to set up closed caption .
when I tried to do it ,is asking me to open an account with opensubtitles.com
I was wondering if someone have done it ,and can guide me how to do it
Thank you
Just set up an account online
Then the buzz will ask you for your username and password when you turn on subtitles
When you say you want to setup closed caption.  You want to enable/display embedded CC ?  LiveTV or VOD/TV Series ?
If so, the option is there in the player just like in BuzzTV 5, you can just press the Green button when you are playing LiveTV or VOD/TV Series to see the Subtitle tracks available.  Also available in the context menu when you press DPAD down to go the options.
However I just tried it on a few LiveTV streams and movies I know have CC, but even though I see tracks showing up in "options - green button" and I select them, they do not display anything.  And in some streams, even though there is only 1 sub track available the player seems to things there are 4 or 5 tracks.  So seems to be interpreting something odd.  Even though regardless of which I select I can't get an CC.  So this needs to be fixed in the player.
I have not tried the opensubtitles.com option on the Classic AI yet, but I'd assume that is very similar to what you can do with VLC when you play a movie and you don't have subs embedded, you can search opensubtitles.com and download a set of subs to use (sometimes you need to try a few different ones to get one which marching the timestamps of your video source - but it typically works on VLC).
4 hours ago, Guillermo Rivas Sr. said:
I followed the instructions ,but didnt work ,I think was easier activate closed captions in Buzztv 5
I think that should be fixed
Thank you
What didnt work?
Didnt find subtitles?
Post more details
To Emporium :I tried green buttom Showing: Auto,Disable ,Track ,none of them worked
To NBS :logged in ,chose English but doesnt work,what I mean is that doesnt show captions
Thank you guys
Is this for LIVETV or for VOD (Movie/TV Series) ?
Opensubtitles option is for VOD (Movie/TV Series), not for LiveTV.
Your experience above (with tracks being shown as available but not showing anything when selected), is the same as mine (as I mentioned in my post).
Thank you guys
your service doesn't have them
CC is not working as it should on the Classic AI.  I tried a few channels that I know work perfectly with BuzzTV 5.   It shows a few tracks available, but no matter what you choose, nothing displays.
I will run a few tests and document them and send to Buzz probably tomorrow.
For EPG, I don't have any issues with my 2 services that I typically use.  So that may be service specific.  If EPG continues not to work with your service, the details of the service should be provided to Buzz.  If it is not reported, it won't get fixed 🙂
  • 4 weeks later...
About Subtitles issue
Hi ,I cant enable subtitles in my AI classic box .
I saw in the Buzz TV G series, an OTA update fixing this problem
Question : I would like to Know if Classic AI is going to have a fix as well ?
Seriously? You think they will update three boxes but not the classic?
Well I am very interested to fix this issue ,I asked because : I- checked my box for a OTA update and say I have the latest software
2- I checked in the google play store ,and I didnt find the update .  .
Thanks for the reply
 You ask about  classic and now you're talking gseries?
It was posted the update for gseries was submitted to Google for approval
Because it was only sent for the G series on the Playstore. All our other models get the update directly via OTA.
It should be sent out to Classic AI and P6 later today.
