Box rebooting
18 minutes ago, nbs. said:
Did you get to the android recovery screen?
Which option did you select?
No, it won't let me. It just reboots every 20min or so now.
are you using the power supply that came with the box?
any external drives connected?
tried a different hdmi cable?
Don't assume it is not an HDMI issue.  Bad HDMI can cause all sorts of odd behaviors, since it can be getting erroneous commands.
Was it working fine and all of a sudden it is doing that ?  Or is it new and has been like this since you installed it ?
Is the box in an enclosed environment (like in a cabinet or behind the TV vent, etc..) ?  Proper airflow ?
Have you tried another power outlet (maybe it has brownouts) ?
If you have another USB-C power adapter that supports the basic 5V 2A output, have you tried swapping out the original power supply, just in case it happened to be defective ?
5 minutes ago, Emporium said:
Don't assume it is not an HDMI issue.  Bad HDMI can cause all sorts of odd behaviors, since it can be getting erroneous commands. Same HDMI on a non-Buzz box and it is fine.
It was working fine and started acting up today.
Out in the open and nothing around it.
Have you tried another power outlet (maybe it has brownouts) ? Outlet is fine. Tested with a tester and it is fine.
Don't have one that will fit and power the box.
Then you are doing it right
I did get it hard reset and it is still doing it. Something wrong with the box
You should be able to select one of the options on recovery screen
Did you select wipe data?
Yes I did and it's still doing it.
