December 13, 2025Dec 13 Has anyone had issues with the volume control not working while using the BT500 remote with the BuzzTV 6 power station unlimited? I have factory reset both the box and the remote, which made it work, then after loading up some apps it no longer worked. Has anyone encountered this issue? Seems like support had no answer for the issue.
December 13, 2025Dec 13 what volume buttons are you using. if you have the remote paired totv use the volume buttons on the top of the remote.. and if u have forced max volume on the big buttons wiill not do anything at bottom of the remote
December 13, 2025Dec 13 this has nothing to do with buzztv 6 especially since you mentioned other apps
December 14, 2025Dec 14 Quote Quote Unpair and re-pair your remote in Settings. That might fix the problem.
April 13Apr 13 Has anyone found a solution for this problem? I am having the same problem with my Power Station and the BT500 remote. The BT500 remote will not raise or lower the volume on my Power Station.
April 13Apr 13 Is max volume off? What are your cec settings? Read here https://stbtalk.com/topic/14681-audio-passthrough-issue-–-buzztv-powerstation-6-dolby-atmos-dolby-digital-dropouts/ Edited April 13Apr 13 by nbs.
April 13Apr 13 9 minutes ago, nbs. said: Is max volume off? What are your cec settings? Read here https://stbtalk.com/topic/14681-audio-passthrough-issue-–-buzztv-powerstation-6-dolby-atmos-dolby-digital-dropouts/ I have to have max volume turned on to get any sound out of the Power Station at all. I will read over the post you have listed to see if I can see anything in it that may help me. Thanks nbs
April 13Apr 13 1 minute ago, sea157 said: I have to have max volume turned on to get any sound out of the Power Station at all. I will read over the post you have listed to see if I can see anything in it that may help me. Thanks nbs hold microphone and say "max volume" and see if you get more sound?
April 13Apr 13 If you reset your remote, and have Max volume set to off, then pressing the volume keys on the remote should show an OSD with volume level. So you can then control the volume to anything between 0 to 100. 100% being same as max volume on.
April 13Apr 13 4 hours ago, Ryu said: hold microphone and say "max volume" and see if you get more sound? Thank you Ryu that works but it just seems weird that I need to use the mic to adjust the volume on the Power station.
April 13Apr 13 2 hours ago, Emporium said: If you reset your remote, and have Max volume set to off, then pressing the volume keys on the remote should show an OSD with volume level. So you can then control the volume to anything between 0 to 100. 100% being same as max volume on. Emporium I will try to reset the BT500 and see it that works. THANKS
