U5 stuck in BuzzTV logos and restarts
7 minutes ago, nbs. said:
Wipe data factory reset
26 minutes ago, Ryu said:
different model but same procedure
Successfully factory reset and rebooted. Where do I find server information for buzztv to gain back access to live TV and VOD?
when it comes back to Home Screen then you will go to server settings to enter your provider info.
Contact your service
1 hour ago, Nahannz said:
Did a new power supply work? I am experiencing the same issue with my U5 now. It loads the buzztv logo and gets stuck there. After several minutes it goes black. The hard reset has not been loading the restore menu.
Yes. It worked.
Thanks for your help! My box is back up and running!
I made a similar post bout my XRS4500 getting stuck on the boot logo.  Tried different hdmi cables, removed transflash, tried different hydro outlets, tried another wall adaptor, tried holding the factory reset pinhole for ever, i basically tried everything, it does not work.  its cooked.
different power supply
What is the purpose of your post ?  Why revive a month old thread that has been clearly resolved already, which is evident from the post prior to yours stating  "Thanks for your help! My box is back up and running!".   Clearly  it is not the same issue that you have.
Yeah its not,  not all suggested solutions will work for everyone, it woked for this users situation but not for mine,  this is a discussion so i am discussing something similar but different out come
Then you should start your own thread and if you already have one going stick to it
this thread is not about the 4500
look at the section it's in
