March 17Mar 17 Author Followed your instructions and even restarted the box subsequently but, still no improvement.
March 17Mar 17 Try creating a new server entry (you can use the same URL and user/password as the one you already have). And see if using the new server entry seems any better. PS: Are you sure you have not changed your default players ? If you go into the menu->Settings->Configuration, what are your LiveTV and VOD/TVSeries players set 2 (they should be the first 2 options on top). LiveTV should ideally be set to "Primary" for best performance.
March 17Mar 17 Author Live TV is set to "Primary" and VOD+TV Series is set to "Backup". However, I found an option called "Tunneled Playback" ON which I turned OFF now. Let me check if things improved. In the meantime please let me know if the servers are configured correctly or they need any adjustment?
