Buzz 6 saying not registered
Ok so 2 issues buzz 6 app says device not tegistered on server but it is. If i use buzz 5 app it works. And when i press guide button on remote it tales me to the server page instead of opening epg. Not sure if these were covered just got my box today
If you are using buzz 5 hit menu button to get guide
Buttons are mapped for buzz! 6
No not that registration.... its telling me that it cannot connect to server... the buzz 5 app connects just fine but the buzz 6 app wont connect up. Already talked ro provider its not on there end. Has to be software glitch
Are you using the same MAC server account on both apps?
MAC sub ?
If it is a MAC sub, then odds are that your provider is binding to fields like DEVICEID1 and DEVICEID2.   So when you change from one software to the other, it may require a RESET on the server panel.  That's not a buzz issue, but rather a Server issue.
Solution.. If they support XC, switch to XC type sub.
20 minutes ago, Emporium said:
MAC sub ?
Yes this is what I am suspecting as well
I will call them to ask to reset on panel. It is mac will see if that does tge trick
Ok if you're using the same account on both apps
That would explain why it works on Buzz 5 and not 6
As its a device id issue, you cant share the same account on 2 apps
Only XC login allows that
Ok contacted provider he is going to reset for me.. wull know in a few hours if it solved it..
Keep in mind that the server will often marry to the first box/software you connect to it after the reset.
