July 16, 20215 yr @Mohamedallyย or @allaboutbuzz maybe someone wants to edit and remove his phone number for his safety. ๐
July 16, 20215 yr 29 minutes ago, Mohamedally said: The box is unfrozen now. Hopefully, it will continue to work. You were very patient. The link to the video helped a lot and saved both of us a lot of time and frustration. Thank you very much. I've done resets plenty of times You will be fine
July 17, 20215 yr Ryu, my friend! Thank you for pointing this out. This old man quite forgot that this was an open forum and not a 1 on 1 chat! Old age is such good fun!
July 17, 20215 yr 2 minutes ago, Mohamedally said: Ryu, my friend! Thank you for pointing this out. This old man quite forgot that this was an open forum and not a 1 on 1 chat! Old age is such good fun! no worries bud. that is what we do here help and protect each other ๐
July 17, 20215 yr 57 minutes ago, Ryu said: @Mohamedallyย or @allaboutbuzz maybe someone wants to edit and remove his phone number for his safety. ๐ Done
July 17, 20215 yr Figured I'd ask in here to not start another thread. Since update TVSERIES and VOD do not work. Then open, get to click play, then says loading profile and never plays. I have reset and factory wiped the box. My other 4500 without update works fine. WHY IS EVERYDATE WITH BUZZ BREAK SOMETHING ELSE? ย ย ย ย
July 17, 20215 yr 4 minutes ago, Joshuas Gems said: Figured I'd ask in here to not start another thread. Since update TVSERIES and VOD do not work. Then open, get to click play, then says loading profile and never plays. I have reset and factory wiped the box. My other 4500 without update works fine. WHY IS EVERYDATE WITH BUZZ BREAK SOMETHING ELSE? ย ย ย ย be honest how many buzz devices do you own and how many of them buzz ย broke them after update?ย Buzz team ย working hard to built us update and fix issues those we have and create new features the one we ask them. why would they break things? seriously makes no sense.ย ย
July 17, 20215 yr Just now, Ryu said: be honest how many buzz devices do you own and how many of them buzz ย broke them after update?ย Buzz team ย working hard to built us update and fix issues those we have and create new features the one we ask them. why would they break things? seriously makes no sense.ย ย I sell buzz so I have over 2000 devices on the street and last firmware had over 1000 with issues which were fixed by a second firmwareย This time so far it's 2 but more will come as the updates get pushed. Im saying every update for last 3 has fixed one thing and cause other wonky issues that have needed a second update or weird fix. ย
July 17, 20215 yr Not everyone got the update No one was supposed to Edited July 17, 20215 yr by nbs.
July 17, 20215 yr Just now, nbs. said: reset your boxย As I stated. Did reset and factory wipe and reset. Didn't fix. ย ย
July 17, 20215 yr 1 minute ago, Joshuas Gems said: As I stated. Did reset and factory wipe and reset. Didn't fix. ย did you do a hard reset? ย
July 17, 20215 yr 1 minute ago, nbs. said: ย Yes. I did reset in options, then did toothpick hard reset. ย
July 17, 20215 yr 2 minutes ago, Joshuas Gems said: Yes. I did reset in options, then did toothpick hard reset. ย Just a heads up There is no update being pushedย Pm allaboutbuzz to get help
July 17, 20215 yr I have messaged them. but there is one puahed It's called V20220714. 2 boxes at two different houses in 2 different cities have it. Maybe a beta pushed by accident. Is there a way to revert firmware?
July 17, 20215 yr Just now, nbs. said: As i stated it is not being pushed. Then how did I get it? Can it be reversed? ย ย
July 17, 20215 yr 5 minutes ago, Joshuas Gems said: Then how did I get it? Can it be reversed? ย ย allaboutbuzz said a hard reset would fix it but you said that didnt work youll have to wait for his input Edited July 17, 20215 yr by nbs.
July 17, 20215 yr Just now, nbs. said: allaboutbuzz said a hard reset would fix it but you said that didnt work youll have to wait for his inputt Yep. Done it twice now. 4 minutes ago, nbs. said: As i stated it is not being pushed. Then how did I get it? Can it be reversed? ย ย
July 18, 20215 yr On 7/17/2021 at 2:50 PM, Joshuas Gems said: Figured I'd ask in here to not start another thread. Since update TVSERIES and VOD do not work. Then open, get to click play, then says loading profile and never plays. I have reset and factory wiped the box. My other 4500 without update works fine. WHY IS EVERYDATE WITH BUZZ BREAK SOMETHING ELSE? ย ย ย ย This was fixed for you via PM.ย
July 20, 20215 yr Yes it was fixed. Then my customer brought it home and now it's working then not.ย She is messaging you as well trying to see if hardware/software issue.ย I can't keep hard reset everyday or two. That's silly. Had another user with similar issue with Dec update and you replaced it.ย
