Box resetting
Over the past few days I have started having problems with my XRS4500. It has started to randomly reset when watching TV. There seems to be no reason for it to reset, it has started happening once every couple of hours etc.
any ideas?
reset or reboot?
if reboot make sure your power outlet is not loose and check for polarity.
Sorry no it reboots not resets, my bad. It’s never really done it before but now it seems to happen I’d say at least once or twice a night. The box is never under any particular load just general channel switching etc
try a different outlet and if on extension cord then try with different extension to eliminate things to see what causing the issue.
or if you want to reset your box maybe that can help too but you will loose all the server...etc settings.
I did have a friend who had similar issues, and it turned out it was his power supply.  It worked fine for the most part, but I guess over time it could not deliver enough current.   Gave him a spare 5V, 2A power supply I had lying around and it never happened again.
Just to provide an update. It does seem to be a faulty plug/wire which affects the box. Thanks for the suggestions.
thanks for the update and glad you figured out. also, thanks for posting resolution for others if they have same problem. 🙂
