Losing Sound
16 hours ago, Rinny1 said:
Same problem also !!
allaboutbuzz said it’s fixed but still ongoing problem  (work in progress??)
small glitch kicking the sound out on default player
secondary player will lock up
Its fixed on Buzz 5
We cant fix it on Buzz 4
Version 4.0.522 is Buzz 4
Responding here should be enough they should see it!
I reported it here I have done my part the issue isn't fixed
though for sure.
though for sure.
no sound issue with my xr 4000
Hi, I am experiencing the same issue ver 4.0.524. How can I update to Version 5 please?
  • 5 months later...
This issue is STILL occurring this issue has not fixed.
I reported this back in 2021 and the problem still exists today.
My Buzz TV XR 4000 is still experiencing the same
issue  the box is upgraded the latest version of Buzz TV
as well.
My Buzz TV Firmware is V20211111
and Current IPTV Version 4.0.530
When I do an update it says it is the latest version is installed
Also do NOT tell me to reset the box I have already did that multiple
times and it does not fix the issue!  I have already factory reset it multiple
times and it does not fix the issue. This is a bug with the BuzzTV XR 4000
software itself that you need to fix.
This is NOT an issue with the provider but the box itself I have
tried multiple providers and I get the same issue weather I use
a portal m8u file.  It is most definately a bug with the box.
The sound just randomly cuts out  randomly the video will be there
and there will be no sound the way to fix it is to change the channel up
one channel and then back to the channel you are watching again and then
you have sound again for a while then randomly it will cut out again at
random times.
This really needs to be fixed please fix this immediately.
as well.
random times.
You are on old software  Get it updated and maybe an attitude change too
