April 15, 20233 yr The guide will not show programs. I have refreshed it and updated it and all but not showing programs in the guide. Didn't have this problem with my other app I used. Please help,
April 15, 20233 yr And what type of sub ? MAC / XC / M3U ? Just curious, have you tried using another app (iptv smarters, stbemu, etc.. - depending on sub type), just to confirm that it is not the service itself having issues ?
April 15, 20233 yr 25 minutes ago, Emporium said: And what type of sub ? MAC / XC / M3U ? Just curious, have you tried using another app (iptv smarters, stbemu, etc.. - depending on sub type), just to confirm that it is not the service itself having issues ? they said they didn't have a problem with other app they used
April 15, 20233 yr 1 hour ago, ezjob said: The guide will not show programs. I have refreshed it and updated it and all but not showing programs in the guide. Didn't have this problem with my other app I used. Please help, Have you cleared epg in menu? If no go pm allaboutbuzz with all your info
April 15, 20233 yr 19 minutes ago, nbs. said: Have you cleared epg in menu? If no go pm allaboutbuzz with all your info they said they refreshed 😉
April 15, 20233 yr Author When I click on epg on the main screen it try's to populate the guide with programs. All it does is spin and never finishes the update. There's something wrong with the Classic 5 software.
April 15, 20233 yr Like NBS mentioned, provide the info to allaboutbuzz. May be something very specific to a particular server. Was it working before ? You still have not replied to my first question.. Are you using MAC/XC or M3U type sub ? My Classic and my buddies (I just checked with him) works perfectly fine with at least 2 services I have tried it with. On the other apps you say it works fine on with your server, have you tried to clear the EPG and have it try to reload. If the server is having issues, then it is possible that what you are seeing in the apps, is something that was cached a day or 2 ago.
April 15, 20233 yr Author The epg is working fine with Tivimate. How do I contact BuzzTv? Edited April 15, 20233 yr by ezjob
April 15, 20233 yr As mentioned several times, contact user "allaboutbuzz" to explain the details (server you are using, what type of sub (MAC/cx/m3u), and description of problem), or email cs@buzztv.com the details. You keep saying your own stuff, but have not answered a single question that has been asked. Have you tried CLEARING the EPG on Tivimate to see if it will repopulate and that what you are seeing is not cached data from yesterday ? IS the problem something new, or has it worked previously and just suddenly stopped working ? Or has it never worked ? What type of sub, MAC, XC, M3U ? Have you tried Clearing the EPG in BuzzTV software as nbs suggested ? Sometimes if there is some corruption in data, it can cause things to misbehave. What version of BuzzTV 5 are you running (when you press the menu key, it is on the bottom left of the menu)
April 16, 20233 yr Author Hello, For some reason my tv input HDMI 3 is for external audio. It has "eARC/ARC" on the input. I didn't know that but I changed the input to HDMI 1 and it's working fine. Go figure.
April 16, 20233 yr 35 minutes ago, ezjob said: Hello, For some reason my tv input HDMI 3 is for external audio. It has "eARC/ARC" on the input. I didn't know that but I changed the input to HDMI 1 and it's working fine. Go figure. eARC/ARC is completely irrelevant to what the box downloads and displays for EPG on the buzzTV5. That is a coincidence. ARC is "Audio Return Channel" and it is used to allow to transmit audio back from the TV for use with Receivers and Soundbars (compared to basic HDMI which is only 1 way audio). It has no bearing on the EPG. I suspect that your service was having issues with their EPG, and they have now fixed it. The EPG you had in your other app was probably previously cached data.
