Delayed audio
I have the xrs4500....I’ve been told by BuzzTV technician to record a program .....to download to an external hard drive (when I record directly to the box it does not work).
when I playback the recording from the external hard drive ....there is an audio delay by about 7 seconds. Very frustrating....
how can I fix this delay?
thank you
What type of recording are you doing and what player are you using?
thank you
If you playback the same recording using an external player like VLC or MX player do you get the same issue?
Or if you take the Hard Drive and connect to a computer and try to play it from there, do you get the same issue?
If so for either, then there was an issue with the stream when it was recorded.
I’m recording a show using the BuzzTV xrs4500. I’m a newbie at this...don’t know what you mean by PLAYER.
I take the external hard drive and when I plug into my computer there’s nothing there but according to my BuzzTV it says it recording....it’s listed under my recordings when completed but when I play it nothing is there
Did you check the folders inside your Hard Drive
It saves to
Android/Media/buzzxr4000tv/recordings
There are media players under menu configuration player
Are you doing scheduled recording or recording from guide?
It saves to
Yes....not there
Scheduled recording
You are leaving the buzz unit on?
Did you find where the media players were?
Yes I leave it on.....
I was able to find media players on the App Store but I was told when I playback the recording on any media player it won’t work if the box doesn’t record.
as I mentioned earlier....it shows it recorded but when I playback there is nothing....I also tried to playback on my computer (I used an external hard drive to store) and it also tells me there is nothing
Sorry if this sounds ridiculous......Besides the App Store for media players...where do I find the menu configuration player
when watching tv full screen hit the menu on remote.configuration.video player
I just did two recordings one on default and one on secondary player
the default is fine
the secondary player is out of sync
the default is fine
I tried recording a one hour show as I was watching it. Once it was over I went into pvr and it was listed under recordings and it WORKED when I selected it but there is an audio delay of about two seconds and the recording was done on SECONDARY
I will try another show later on DEFAULT and see what happens....
but I hate to think I need to record as I watch it live....
no, just make sure you are on default
I have scheduled while recording from guide and manual scheduling many times no issues
From menu ....when I select default and the click back.....it automatically goes back to secondary
you hit ok and check the one you want
Ok...switched to default.....I will record a show soon but I won’t be watching it as it’s recording....so I’ll see if it works and hopefully no audio delay
buffer time was set at 3 seconds....will this affect the audio delay?
8 minutes ago, nbs. said:
never used or changed the buffer  since i got the 4500
Ok......I’ll let you know later how my next recording turns out
So I preset the recording for another show....and I made sure by double checking a few times  it was set to default. The recording worked but the audio is still delayed. ......I don’t get it        😞
Also forgot to mention......when I was watching the recorded show......for some reason it bounced to secondary from default. As I said.....I even checked a few times and made sure it was on default
