January 25, 20233 yr First turn on developer options by goin into Device preferences. Then About then scroll to bottom and click repeatedly on Android TV OS build till you see message on bottom of screen that your only a few clicks away from being a developer. Click back one menu. You will now see Developer options section. Under Developer options scroll down to: Window animation scale. Should be set to 1x. Change to .5x Transition animation scale same change to .5x Animator duration scale same change to .5x This will increase the responsiveness of the GUI. I might be new to the forum but I've been a Tech since 1998. Cheers Enjoy,
January 25, 20233 yr Welcome to the forum. However please keep in mind that changing anything in the developer options can cause some apps to misbehave, as harmless as some of the options may seem. These are typically harmless, but I have seen some apps do strange things even depending on how certain things are implemented. And the impact is not that dramatic on an android box, as it is when you disable these animations on a windows machine.. 🙂
