Recording stops when box is suspended
I have a xrs4500 ver 5.0.793 which stops recording the current tv live show when I hit the power button which suspends the box. Actually it records for about 12 seconds.
Am I missing some settings?
The stream stops when you put the box into suspend, as internet goes into hibernation
That is why your recording stops.  You could always just leave the box on the home screen and it will record in the background.
The box needs to be ON for the recording to work
That is why if you have any recordings that are scheduled and the box is off, it will wakeup to record.
Is there any way for the box to suspend after the recording finishes?
Will it continue to stream after the recording finishes?
I have the app set to stop streaming after 2hrs of inactivity (you can adjust to your liking).  That way even I fall asleep. it will exit to the main screen and stop streaming.
No there isn't a way for it to suspend after the recording finishes
And if left on the home screen to record in the background, it won't continue to stream after the recording finishes.
