Can't record VOD & TV Series with BuzzTV5 firmware
Factory reset & Updated from Buzz XRS 4500 Firmware V20211108 to BuzzTV5 firmware 5.0.793 version v20220919
I can't record VOD & TV Series to internal box memory or USB drive but I can record Live TV.
Any suggestions to be able to record?
you were already told in other thread to download
you were also told the same at another site
You do need to make sure that you select the proper location for the "download storage".
From LiveTV, Menu->PVR->PVR Options  And the last option should be "Download storage".  Select it, and make sure it is pointing to your storage location.  By default it is NOT set.
Then from PVR or TV Series, you should have an option on the far right when you select a title, to "download".
Simple.
Simple.
VOD 😉
by the way?
how many threads on same topic do you plan on starting here?
just curious cause if I need to set to ignore before you annoy me...lol
14 minutes ago, nbs. said:
Same thing on two other sites
yes I know
that's why I asked...lol
they know how to start threads but don't know how to follow advice
5 hours ago, dishuser said:
VOD 😉
Yes, that is for VOD.. the Recording location for actual LiveTV PVR is the first setting in that menu which is the recording location.   I know it seems strange, but in the PVR options menu, you have the recording location option on the top, and the download location for downloads, at the bottom.   I do believe the recording location is set to some default.  But the download location I believe is blank if it is not manually set.
read first post
