Upgrade From  BuzzTV4 Beta firmware to  BuzzTV5?
4500XRS..  How do I Upgrade From  BuzzTV4 Beta firmware to  BuzzTV5 Beta firmware?
check update and post what firmware is currently on your buzz
also post buzz version
no such thing as beta for either version
Odds are, if you do a factory reset on the box, it may automatically upgrade to BuzzTV 5 when it comes back up.  I have 2 buddies that wanted to upgrade.  They did a factory reset to start clean and the boxes automatically upgraded.
I will try to reset & post the result. Problem is they sat it can't be reverted back in case there's a problem
