Power button tv and reciever
Is there a way to program the powers button to turn off the TV and the receiver at the same time like my fire stick
  • 4 weeks later...
3 hours ago, mopar.man said:
where do i find the manual for the 4500 keyboard type remote? Thanks james
I'm guessing you mean the arq-100??
Hi thanks just got this thanks , gave it a try so far still not quite getting it to work. flashes and such but wont seem to take the remote signal will keep trying. Thanks for the info.
Try it more ,I had some problems till I got it work ,all and all the remote is awesome 😁👍
thanks finally got it was not using original remote was using cable company remote. Works great ..
