July 19, 20206 yr Not having many issues but would it be possible to have an option to change audio sync in a future update? I've seen it on other apps and works well and quite a handy feature to have.
July 19, 20206 yr Author Yes I have like I say its not a massive issue just sometimes you get a feed that's slightly out of sync and option to change sync would be good. Just a suggestion for future updates not a fault with the player or box.
July 21, 20206 yr I think is from the server too, happened with me today with one of the channels but when I went to the HD section the same channel had no sync problem.
July 22, 20206 yr On 7/19/2020 at 7:35 AM, spudnuts said: Not having many issues but would it be possible to have an option to change audio sync in a future update? I've seen it on other apps and works well and quite a handy feature to have. Will look into this and see if we can add it to a future update.
