November 22, 20223 yr Hi, is there any way to display 5 digit channels in the guide or categories? It only shows the first available 4 digits. Adding to favorites you get …01 what ever is the last two digits of the ch. Thanks
November 22, 20223 yr Would help if you specify what box, and what version of Buzz you are using (hit the Menu button, and it should be listed at the bottom of the menu on the left). Edited November 22, 20223 yr by Emporium
November 22, 20223 yr Author Sorry to clarify it displays …01 for 5 digit ch in faves otherwise the full 4 digits for others
November 22, 20223 yr 24 minutes ago, Buzzed- said: Do you have 5 digit ch? no because the services I use don't have 10,000 channels
November 22, 20223 yr but if you are in epg you highlight on of the channel it will show you 5 digits on top left corner
November 23, 20223 yr Author Yes it shows in the top left corner but it would be nice to have when scrolling through or categories
November 29, 20223 yr @Buzzed- FYI, should be fixed in the latest update. I don't have servers that have that many channels, but you can certainly try it out.
November 29, 20223 yr 1 hour ago, Emporium said: @Buzzed- FYI, should be fixed in the latest update. I don't have servers that have that many channels, but you can certainly try it out. Servers basically need to have more than 9999 channels to get to 5 digits. But it's been confirmed fixed on our testing.
November 29, 20223 yr 9 minutes ago, allaboutbuzz said: Servers basically need to have more than 9999 channels to get to 5 digits. But it's been confirmed fixed on our testing. yup I can confirm its working and I can see 5 digits now @ info bar, categories, and in guide. 🙂 thanks 🙂
