How to program remote xsr4500??
I was enquiring about a replacement BT-100 for my XRS 4500 MAX, and was informed by cs@buzztv that the BT-100 / 200 are discontinued. The new XRS 4500's are being shipped with the BT-300 (BT-400 I think is the same unit). The new boxes don't have the smart remote app as they are Android 9, and the app is for Android 11. As I understand it Buzz is working on an update that will turn the back light on and off, and allow the colour button mapping.
However, you can program the BT-400 manually as outlined in the instruction manual. Hope that helps.
I don't believe that the app is android 11. Last I heard they were going to be adding it to the android 9 units
