Beta system update
Hi guys ,I downloaded the other day the buzztv beta system update 2.220914 ,FW version V20220919 , and the IPTV version 5.0.779 and I saw that the box doesn't come back from the stand by mode, I have to unplug it from the wall to get the box back to life 😐 is there any official update coming for the xrs4500?,I'm still testing it since I got this beta few days a go but this is the most annoying bug that I see for now.
Edited by Nelutz
BTW: It is no longer Beta.  It has been out of beta for quite a while now.  The update procedure installs beta first, but them updates to the latest (non-beta 5.0.779 right now).
What remote are you using ?  IR or BT ?  If you are using a BT remote, have you tried just pointing the remote to the box and and using the IR only ?
Ive tried with both ,but seams like it doesn't want to come back from sleep mode ,it comes back but only if I do that within maybe 20-30min after that doesn't want to come back.
