June 8, 20206 yr Hello guys...i see these 2 remotes ( IR-100L - Luminous Remote & ARQ-100 ) work with buzztv xrs 4500, from them wich would u recomend and do all keys work with them ?
June 8, 20206 yr The first remote comes with it. Second one is updated model you can purchase. I have ordered the second one due to the fact it has the built in keyboard.
June 8, 20206 yr 19 minutes ago, Mark said: The first remote comes with it. Second one is updated model you can purchase. I have ordered the second one due to the fact it has the built in keyboard. Unless things have changed the 4500 is still being advertised as coming with the bt-100 not the ir-100l
June 10, 20206 yr Author So u guys mean either one all the keys will work ? like if u hit LiveTv will take u to livetv or hit Vod will go to Vod ?
June 10, 20206 yr 2 hours ago, Benfica said: So u guys mean either one all the keys will work ? like if u hit LiveTv will take u to livetv or hit Vod will go to Vod ? Yes will work ,right now I'm using 3 ARQ-100 and they work better than any remote so go ahead and get it , you will not regret it 🙂
June 10, 20206 yr 13 hours ago, Benfica said: So u guys mean either one all the keys will work ? like if u hit LiveTv will take u to livetv or hit Vod will go to Vod ? I have both and for the most part the arq-100 works THere are a couple of functios on the remote that dont work for me but i caan use the kb The il works great too
June 13, 20206 yr Author Guys...just got my Xrs4500 !! And wow, ive been a Mag user for many years 😩, good box also but my Buzz is great, my reply to the topic is because i wont be in need of purchasing a remote ( for now ) because the one the box brought works real good ! May u all have a great weekend !!
