Recording with E1+
I'm trying to record with this box and no matter which way I do it the recording always stops before the end....very frustrating......I'm using a 32 GB stick.....has anyone been successful here at recording?.......am I missing something here?.......any help would be appreciated.........thanks
how close to the end?
are you adding extra recording time?
it's all over the place.....sometimes only records 20 min of a 2 hour recording.....sometimes records1 3/4 of a 2 hour program
You on buzz 4 or 5?
If I remember correctly, don't think the E1 had the required performance to run Buzz5 (I could be wrong).
I don't even know what buzz5 is...lol.....I'm new.....are you talking about providers?
So I just tried formatting my stick to NFTS and tried recording "The Batman" movie.....I got an hour and a half before it quit recording and then subsequently locked up my box
the builtin app
So are there any boxes Buzz make that can actually record for 2 or 3 hours without issues??
I can record with my 3900,4500 4900
Currently testing x5 and u5
press menu button
what version shows at the bottom?
also if you go to update screen it will show you firmware and software versions
