September 20, 20224 yr Does anyone know if the BT-100 or BT-200 remote will work with the U5 box? The BT-400 will not work the way I need it to (don't want it to control the TV on & off). I am using the IR-200 remote to control the U5 right now and it operates the way I need it to, but the IR-200 remote is not backlite, I would like to get a backlite remote.
September 20, 20224 yr Should work just fine just make sure you connect it to blue tooth I would use the BT 200 it's a lot nicer remote
September 21, 20224 yr 1 hour ago, Emporium said: BT200 also has TV volume control buttons 🙂 So 2 extra programmable buttons. ya it has same button layout as the ir-200
