XRS4500 audio and video on recordings not synchronized
I noticed that when I record a program on the XRS4500 box, the audio and video are not synchronized. Video is behind. Is there any way to fix this? I should point out that my software is up to date.
Peter
When you say you software is up to date, is it latest beta, or latest public release ?  From Menu, on the bottom, what version of software are you running ?
Also, as nbs has posted in order threads, this might help for users running buzz 5 and android 9
https://www.mediafire.com/file/epmf5i0suejl6rj/com_buzz.services.pvr_33_5056428e-2cad-4bbe-9a31-4e13bdb55857.apk/file
I typically record on my 4900, and haven't done much recording on my 4500, but when I had tried it in the past it was perfectly fine.  Are you recording to an external USB drive ?  If you are, just for a test, can you change the destination to the internal storage and try a small recording to that ?
