Weather on Home Page
I noticed on the Home Screen that my location in the weather screen is shown as Georgetown CA, instead of Georgetown ON. It shows the current temp as +27C, but in Georgetown CA it is +2C, and at my location it's +12C.
Is there a way to set the weather location on the box to match my true location?
Thanks.
I don't believe there is anyway to change it at this time
Email buzz with your issue and see what they say
Thanks for your help. I will update this post if their response is helpfull.
Update:
I conversed with Buzz on this issue, and in a nutshell, they feel that the app is getting its info for Georgetown CA from an incorrect source. Their dev team  have sent this info to the weather app creators to check on this. Once they establish the right source for the weather information the problem  will correct itself.
BuzzTV's service is very good to deal with!
Just updating this post. I e-mailed BuzzTV support to follow up on my April 13th chat with them on this issue, and they've now told me that I should contact stbtalk about help with this. Seems I'm back to square 1. Is the weather app (widget) part of the Buzz5 beta?
If it's part of the beta I'm sure it will be resolved at some point. It is one of those small details that might not show up often since it is location specific.
Thanks.
I know of one person who is getting London England's weather instead of Ontario
It sounds like the second person didn't know what you were talking about as it's the weather app guys who need to fix it
Did their weather app guys supply the beta team with the app? If so I will send them a copy of the transcript and see what they have to say.
Thanks nbs. I sent them a polite e-mail saying that I followed their suggestion to contact stbtalk, and they referred me back to BuzzTV, as was their app that needed fixing. Unfortunately, they can't fix it, as they are using a free weather service from an outside source.  I will pm allaboutbuzz later and see what he thinks.
Thanks to all for your help. Regards, Dave J.
Am one who answered the ticket with that information about the weather service
So no need to PM me about it.
