Cannot Load portal: not supported issue... again
Hi there,
As many others, I have this error for a month now.
m3u is working without problem but for a month now (it worked for almost a year), xc api refuse to load.
I checked with my provider. He gave me another url and suddenly it worked.. for 10 sec.! When I left app then get back, same error!
  • Tried with / without vpn
  • it's working with other apps (Tivimate / Implayer)
  • it worked for almost a year then stop working recently (app update?)
  • Cleared data / cache
So it definitively comes form the app/box, not my provider
Any ideas?
Fred
try to post in the section for your model
8 hours ago, Fred Perso said:
Hi there,
Any ideas?
Fred
Are the server urls the same for the M3U as the XC Login?
Glad it fixed your problem.. But I don't see anything in the Release notes about XC API.  Unless it was very minor that it was fixed, but didn't make the list.
V5.0.0957
New Buzz 5 App Update
Jan 19th, 2026
Changes:
- Updated Weather Widget**957**
- **Fixed Catch-Up on Mac Servers**
- Added New QR/Web Server Feature to Server Settings to allow you to edit or add new
servers remotely via Code or QR on website
- Fixed Subtitles Bugs
- Update Primary and Backup Players
V5.0.0957
Jan 19th, 2026
Changes:
 this update are for certain boxes? mine x5 is still on 956.
Not 100% sure, but my xrs4900, E2, and my Classic all got it so far.  Have not powered up the others yet.
From LiveTV, did you try going to Menu->Settings->Check updates ?
Right now just Android 9
Should get rolled out to Android 11 tomorrow or Wed
The update was just to update the Weather Widget though, as that company required some API changes.
I see that all suggestion point to the fact it's not related to the box/app itself but because of cloudflare.
But in that case, how come it worked with same box and provider for a long period of time then suddenly not anymore but it's still working for other app on same box 🤔?
If it was on provider side Cloudflare), it shouldn't work at all on xc api, on every app. But it work xc api with other app, and on buzz tv it works on m3u with same credential. I maybe dumb or miss something but I cannot see what cloudflare has to do with that.
And vpn has no impact because I tryied with and without and no change.
I PM you
Try using Fast Login for Login Type instead of Default
