Epg not upda
The epg guide for live TV is not updating.  I have the same stream/server on the iptv"s own app and it updating fine.
Help?
from Menu->settings->configuration, scroll down to EPG section, and Clear EPG.  This will clear out the current content and force it to re-download it.
Also in the same area, you might have the options for EPG type "xml or server".  Try toggling it clearing does not help.
server type is not available when using mac
I tried all of the above suggestions.  EPG will not refresh and update. Buzztv 6 not worth it! Same Streams on other apps working fine. Go figure!
