October 8, 20251 yr When streaming movies on my P6 the movie won't download. I have tried this on several different apps including 3rd party apps and apps within Kod, the result is the same...the movie will not download. As I am trying different apps and the result is the same, I'm thinking it's a device issue? Is anyone else experiencing this problem?
October 9, 20251 yr 3 hours ago, nbs. said: Have you tried downloading movies using buzz 6? Meant to say buzz 5
October 9, 20251 yr I just used BuzzTV 5 and downloaded a movie and worked without a hitch. Also used BeeTV which I have installed and configured it to download using Advanced Download Manager, and I downloaded another movie without an issue also. This one download nice and fast, since ADM split it into 4 threads so took about 4 minutes to download. BuzzTV is set to download to internal storage. And I have ADM set to download to my installed Nvme SSD drive. Keep in mind that this box runs on AndroidTV 13. So your apps need to be AndroidTV 13 compatible. BuzzTV 6 does not have download option yet, it is in the plans as far as I know.
October 9, 20251 yr 20 hours ago, Shari Schwarzenbart said: When streaming movies on my P6 the movie won't download. I have tried this on several different apps including 3rd party apps and apps within Kod, the result is the same...the movie will not download. As I am trying different apps and the result is the same, I'm thinking it's a device issue? Is anyone else experiencing this problem? Make sure you Allow Files and Media under permissions for the apps you're trying to download from
October 9, 20251 yr Author One of the apps I am having a problem with is Bee TV. What exactly is Advanced Download Manager and how can I get it?
October 9, 20251 yr Author One of the apps I am having a problem with is Bee TV. What exactly is Advanced Download Manager and how can I get it? I just went into the settings of Bee and I see a choose default player and I see the option "download with advanced download manager". If I click that, is there also an app to install with it?
October 9, 20251 yr 1 hour ago, Shari Schwarzenbart said: One of the apps I am having a problem with is Bee TV. What exactly is Advanced Download Manager and how can I get it? I just went into the settings of Bee and I see a choose default player and I see the option "download with advanced download manager". If I click that, is there also an app to install with it? That app uses external apps to do a lot of things Like video playback calls out Players to playback what you want to watch, Like VLC, EXO,MX But you have to have these player apps actually installed on the device in order for them to work. The app doesn't give a way for you to install them yourself I think the same thing applies to this Advanced download manager I searched for it on Google Play and its not there, so I am really not sure where its from Sounds like a rabbit hole mission to find this I will forewarn you though about downloading movies etc from apps like BeeTV A lot of times they just stream torrents, and if you download torrents without a VPN. ISPs will report Copyright infringement notices and warn you In Canada its simply just a warning letter, but in America its been known for movie studios to sue people for torrents.
October 9, 20251 yr 4 hours ago, Shari Schwarzenbart said: One of the apps I am having a problem with is Bee TV. What exactly is Advanced Download Manager and how can I get it? I just went into the settings of Bee and I see a choose default player and I see the option "download with advanced download manager". If I click that, is there also an app to install with it? Like allaboutbuzz mentioned, that app does depend on a lot of 3rd party external apps (and it's dependencies have changed a lot in the last few months). So unless you know what you are doing, you will have a hard time. "Advanced Download manager" is available from Google Play store ( search for "com.dv.adm", "ADM" or ecven "Advanced Download Manager" and you'll find it ). BeeTV supports one other download manager also which I don't recall, and I am not in front of it now. But you do need to pre-install the dependencies for any of the options to work. But like I mentioned, even BuzzTV 5 (which is also installed on the P6), with a proper service provider, works flawlessly for download VOD. Bottom line, the problem is NOT the box, it is the setup of your apps. However this is where I will stop, since this is a Buzz/BuzzTV support Forum, NOT a 3rd party app support forum. There are other forums out there if you need support for specific 3rd party apps.
